I am about to order the EK KIT X360, which has a included DDC 3.2 pump with 120mm fan mount holder.
As I will mount the radiator in the front, I will have little space left, and therefore mounting the pump on top of the bottom chassi fan would be a great solution.
If I buy a 120mm fan and change it from my 140mm bottom fan and then mount the pump on top the new 120mm, would that be a good setup? Or would it have a negative impact, as in more vibration or anything like that? Is it worth buying a new fan for this?
My setup would look like this:
Should I change the setup or does it look good?
Thanks!
Thanks!
