- Feb 1, 2009
- Illinois
My apologies if this is either in the wrong spot, or has already been discussed, but a quick search didn't find anything promising.
I currently use a Logitech G500 after using a Logitech G5 before that mouse. Now I've been playing BF4 lately and noticed that I'll be hoping right click to zoom, and every now and then I'll just unzoom and zoom again quickly (while I was still holding). So needless to say, one of the buttons is on its way out.
I started looking for a new mouse last night and found some options. I've decided I don't want to go insane for the budget, but I do want a "gaming" mouse, so it has to be laser tracking, adjustable DPI, preferably extra button that can be programmed, and Logitech is a bonus because I already have some of their products (G110 KB and the above mentioned G500 Mouse).
Anyway, I came across the Corsair M65, and the Logitech G602. They are both a bit different, and that's what has me left with questions.
1. Does anyone here use wireless mice for gaming? I've always liked wired mice, but I can see myself using a wireless as long as it doesn't affect gameplay.
2. I can tell you right now that I don't often use over 2000 DPI, and I usually use much lower (~1000) for gaming. Would the 2500 max sensor on the G602 be an issue? And I can only assume that the 8200 DPI of the M65 would just be wasted...
3. Does anyone have suggestions for comparable mice with comparable specs and price? I'm definitely open to new options here.
Thanks in advance!!!
