- Jan 2, 2012
I have a very odd problem, which is slightly ironic to be posting in the Overclocker Forums. I need to find a way to underclock! I have a motherboard I recently picked up, and I've run into a big problem that I'm not sure how to correct so some insight would be greatly appreciated. I will share the problem and attempted solutions, then list my system specs.
I have a MSI G41M-P33 motherboard, with a E7500 Intel CPU. The CPU is a Core2Duo, with a stock clock of 2.93GHZ. The problem is, that at stock BIOS settings, the MSI bios/motherboard automatically overclocks the chip to an unstable 3.6GHZ. This would be great, but causes me many problems and doesn't last more than 10 seconds in Mprime(Prime95 for linux).
I can't, for the life of me find out how to get this chip back down to factory speeds. The Multiplier is locked on the CPU at 11, which is the stock ratio, but the BIOS automatically sets the FSB to 333mhz, instead of the CPU's stock FSB of 266. I can't get the FSB any lower than 333mhz, and can only adjust it between 333mhz and 833mhz.
I have tried loading "Optimized Defaults" and "Fail-Safe Defaults" from within the BIOS, but neither lowered the FSB. I have searched the BIOS for any performance modes or anything that could effect this. I have flashed the BIOS to the newest version available on MSI's website, which is v7.C.
I'm really stumped on this one and would really like any insight from anyone who has experience with MSI boards/BIOS settings.
Specs:
Mobo: MSI G41M-P33
CPU: Intel C2D E7500 @ 2.93GHZ
BIOS: v7.C
RAM: Corsair XMS3 1333mhz (clocked at 1066mhz) 2x2GB
GPU: GTS 250
PSU: 600w OCZ GameXstream
Specs:
Mobo: MSI G41M-P33
BIOS: v7.C
GPU: GTS 250
