- Nov 25, 2001
- Niagara Falls, Ontario, Canada
Hi guys,
I'm desperately trying to get some useable systems up and running, I've got a K8T Neo, history unknown that won't even twitch the fans when I goose the power header. CPU on it is a 3000+ Newcastle that came with.
The BIOS is soldered on, so not likely to be able to hotflash it. I've tried 4 PSUs on it, which power up Socket A boards fine, they're various not all that great units between 300 and 475 watts. The 300 is a sparkle, they claim to have fairly beefy rails. I thought one of them should at least POST if, even if it would be too weak for drives, good gfx etc as well.
Caps looks excellent, no heat marks on any of the MOSFETs or anything looking burned.
So, is there any common failure of these I could check for, or odd tricks to get them going?
Don't have any other s754 boards to test the CPU.
Thanks,
Road Warrior
Thanks,
Road Warrior
