- Feb 4, 2017
- Marion, IA
Alright guys, I have an MSi z270 Gaming M7 board, with an i7-7700k chip. I currently have the board stable at 5.1ghz with a vcore of 1.385 volts. Temps peak at about 63*c while running Prime95. *water cooled with a swiftech 320 x2 prestige*
My question is, has anyone had experience using the onboard "easy overclock" if you will?
They claim MOST chips should make it to 5.2ghz with there "set it and forget it" setup. I see that it volts the chip to 1.502 volts, which according to Intel is within spec for that chip, but I know most here say they dont like to go over 1.42 or so for daily use.
Just curious what everyone else thinks, or if anyone has had experience with these new boards and features?
Thanks in advance!!
Thanks in advance!!
