The handful that I have seen come through have had issues.
What issues? I am curious.The handful that I have seen come through have had issues.
To OP: At a high level, I don't see anything wrong with this offering. Looks like 6 phases for power, either 4+2 or 5+1 (CPU/mem). They have heatsinks on them. No idea what is below them, but, it will(should) easily handle any overclock on air/water you can throw at it (4.3-4.7Ghz).
I added more to my previous post, note...
Unless you get a GREAT CPU and/or willing to delid, you will not be getting much over 4.6Ghz for daily driving duties.
Yeah, regular version and the GD45. Whoops! They need more variation in their name other than "gaming" behind everything.
That is what you think...I saw that when I went to quote you lol, as for deliding... Ill hold off on that for the initial build, but when it comes time I want to try and squeeze some more juice out it is definitely something I'm considering. 4.6 is the minimum Im looking at OCing to with this. When I revamp for the water setup I will have more than enough cooling to push 5.0Ghz.
I have a PA120.2 and MCR320 cooling ONLY my CPU which is a good one, well, above average at least (was great before I degraded it, LOL!). I need 1.49v to be 'stable' at 4.9Ghz. And my temps, without delidding, are at the max (and this is in a 20-21C room with my fans cranked). No way I would run over 1.4-1.45v 24/7 if I planned on keeping my CPU like you did your last one.
You will need a good chip, and likely have to delid it to reach that goal. Im a betting man and wouldn't bet on your 5Ghz goal...though it is possible, just not likely.
You like your room cold I guess... 15C is a cold room (59F. Typical house is 70-72F/~22C). Most GPUs I have idle almost 10C more than ambient...(open air/benching station).
Yeah, you have a bit more rad than me, however, the raddage isn't really the main issue. Its getting the heat out of the chip. You will more than likely NEED to delid. I would check the voltage on the CPU first. If you need more than 1.45v for 5Ghz, I would say you lost the lottery and do not delid.
What I meant by 'like your old chip' was simply meant how long you kept it. You are rolling the dice rocking 1.45v+ 24/7 with ambient cooling.
Not sure on that either. Perhaps 5+2 in that case? Regardless, your limit will be heat or voltage on the CPU, not the board.
