- Feb 19, 2013
Hey guys- iv had a pretty depressing morning. So I have the listed motherboard.
I7-4770k
MSI Z87-G45
GSKILL SNIPER 1866Ghz 2x4GB
ASUS GTX 780 OC-DC2
H110 liquid cooler 4x140mm push/pull
Alright so I did a delid on the 4770K last night (vice method) everything went well as far as I can tell. Ran a base prime95 test at stock clocks and was seeing no more than 54C. Major success- being down from 70ish before the delid.
Okay so I clocking it up little by little, ended up being pretty stable for 30 minutes at 4.7ghz and here's my settings for the clock
CPU Voltage
1.5v
CPU Frequency
4700
CPU Multiplier
47
CPU Ring Ratio
43(4300
CPU Ring Voltage
1.2v
System Agent Voltage
1.088v / (+ .250)
I/O Analog Voltage
1.2v / (+ .1950
I/O Digital Voltage
----- / (+ .1950)
BLCK
100
Ram running at 1600mhz @1.65
After around 30 minutes I was seeing temps never going above 80c. From what iv seen, not that bad. So I realize I'm running higher Core and Dram voltage to keep it stable. After running prime95 for about an hour temps looked good again hitting around 80 max but not sitting there.
So I fire prime95 up this morning to get an endurance test on this clock- well about 30 minutes in the box shuts off. Only this time not to turn back on. It fires but only for about a second and kills right away. Doesn't try to restart itself. So I shorted something somewhere. If it's the board no big deal it's 3 weeks old. The processor I just voided the warranty on. Based on the temps I saw I have a hard time seeing it as the CPU even though I was pushing 1.5v. I see people kicking 1.65 as long as temp is under control. Ram on the other hand I was pushing pretty good (will be testing ram in the next hour with 2 of the exact same sticks from another build). Honestly though i can't seem but think it's the board, after reading around I heard these have slightly weaker VRMs. I have a case started with newegg, i can ship it out tomorrow. I just am slightly worried I fried the processor.
Any thoughts? Opinions? Experiences to share?
I7-4770k
MSI Z87-G45
ASUS GTX 780 OC-DC2
CPU Voltage
1.5v
CPU Frequency
4700
CPU Multiplier
47
CPU Ring Ratio
43(4300
CPU Ring Voltage
1.2v
1.088v / (+ .250)
I/O Analog Voltage
1.2v / (+ .1950
I/O Digital Voltage
----- / (+ .1950)
BLCK
100
