Hi, my box stock cooling for 4670 i5 processor doesn't seem to be enough to keep the temperatures low. I was thinking about Zalmans 8900 series, but I think it won't fit because of the GPU. The clearance between motherboard and power unit above is only 65mm. I have a dremel if some trimming will be required. Please recommend me something, because my CPU temperatures are too high in my opinion. The only coller which i found, that should fit is the noctua nh-l9i, which price is high, and performance seem to be a little low compared to it. I'm not afraid to do some modding on the cooler if needed. And my case is Cooler Master Elite 130.
Best regards, Mateusz.
