- Feb 13, 2010
- Missouri
Your beating a dead horse wagex.
no picture willl prove anything
After reading through some of this thread I can see you are set on not listening to the advice and proof we have provided for you. the newer sandy/ivy/haswell chips will outperform any c2d chip at stock speeds not even overclocked. download cinebench and bench your c2d quad and post the results. c2d chips needed more cache because the memory controller was not integrated into the chip like sandybridge and and newer chips ivy\haswell. since the implementation of IMC's the amount of cache needed has dropped and the only reason that 39xx\49xx chips need more cache is because the can handle up to 64gb of memory.
You sir are no fun at all.Deleted ~20 posts or so...
There's no need to continue arguing C2Q vs i7 since there are plenty of valid tests out there comparing processors, some of which even linked in this thread. Providing and explaining valid data is really all that can be done from either side. If arguing continues after that, then it eventually becomes futile.
Plus, that whole CPU comparison topic isn't even what this thread is about. The issues here are about an overheating 7900GTX and a GTX780 can won't run in one of the OP's PCs. The processor being used is irrelevant to those issues.
+1 ^^... an indicator of poor contact likely. Perhaps the card was jarred in moving from PC to PC which knocked it loose a bit?
Also, with the cooler attached during or after heavy load, are the fins on the cooler actually warm to touch? If not, that could indicate poor heat transfer.
