- May 17, 2003
- South Carolina
Finished installing both of these coolers on my SLI 570s this morning, been messing with them a little today.
Installation was kind of a headache, because the glue has to cure for 5 hours on the ramsinks and vrms. I planned to install them on one card at a time, so I could use the computer in between. I ended up messing up one of the vrm heatsinks(forgot to put the tiny thermal pad on the nearby chips that are raised up higher), so I had to use some glue from the second kit to finish, which kinda forced me to start the install on the second card as well. (Glue is only good for 15 minutes after you mix it, according to the manual)
You get a TON of ramsinks and vrm sinks in the box with it, I think 3 seperate kits worth. Enough left over to do several older cards if you wanted to
I tried turning it up to 85% in msi afterburner, and I can see the RPM going up but I can barely hear them. They are nearly silent, a HUGE difference from the stock MSI vapor chamber coolers.
Left at stock clocks, the top card used to stay a constant ~80+ C while gaming, and the bottom one ~70+ C.
With these monsters installed, I'm now in the 50-60C range on the top card and 40s on the bottom card under my normal load.
Great success
Great success
