- Jun 22, 2013
- Thread Starter
- #21
Try testing with case laying flat, side open and fan turned over so it is drawing air out of CPU cooler. I have often seen this lower temps but 5c+.
I think this is caused by the air blowing onto mobo > hitting RAM, GPU, I/O housings, etc. > coming back alongside of cooler and being sucked back into fan.
Thanks for the idea. What do you mean by the "fan turned over" though?
I kind of suspected it was the tight "box" created by the bottom panel, the GPU and the RAM walling the heat in. But I thought the front intake fan should have provided some fresh cold air to the cooler, and the exhaust fan (previously on) should have helped sucking the heat out. But neither ended up making a difference. That's why I'm at a total loss.
