- Nov 11, 2003
- Bloomington, IN
Here is my story:
I took the board out of me case to install NB-1 cooler on the NB, and move the NB synk to the SB. I did this, put it back together... and when I connected the power connector to the mobo, the CPU fan started spinning for about a fraction of a second, THEN it stopped, making some odd clicking noise.
I then power my computer back up, and it does not do anything, just sits with a black screen. So I just figure it is a cold boot issue, so I just reboot, and nothing still. I shut down, make sure everything is connected right, and all is.
I power back on, then start to smell somehting nasty, and the computer shutts off after about 3 seconds. I take the HSF off, and take the processor out to find burn marks on it.
Could it be because of static electricity? Surely not, because I was extra careful with it, and I have taken my PC apart many times before. It is not because of the OC either, nor the voltage. It was at 1.8volts, and had more than adequate cooling on it.
Also, while the computer was on, the fans never stopped spinning, and the HS was seated correctly at all times (it was screwed onto the mobo).
So why one earth would this happen? I am baffled... I am also hoping that the rest of the system is not fried. I ordered an 2600+mobile from excaliber, should be in wed. should there be any possibilities of that one getting fried too? This is the first time it has happened to me... anybody got any clues as to what cause this mishap?
