- Mar 18, 2011
Ok so here we go i have got my shopping list together after lurking around here and extremesystems for the past few months, and reading everything i could get my eyes on from how-to's, things not to do, things to do and so on and so on you all get the point, so i have some what educated myself to my extend i do have a few questions but first let me list my build componets as far as the periphials go first.
Os- Windows 7 ultimate 64
Motherboard(sold out everywhere but ebay d***it)-Asus Crosshair IV Extreme AM3/ AMD 890FX
Processor- AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo Socket AM3
Graphic Cards- 3x XFX HD-587X-ZNFC Radeon HD 5870 1GB 256-bit DDR5 PCI Express 2.1 (yes i checked it will support 3 way crossfire each card has to bridge slots, although the one that is labled HD-5877-xn... whatever only has one per card)
Memory- G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
Data Drive- 3x Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb in raid0
Os drive/game drive- 2x OCZ Agility 2 OCZSSD2-2AGTE60G 2.5" 60GB SATA II MLC Internal SSD raid 0
Optical Drive-2x LG Black 10X Blu-ray Burner
Dedicated power supply- RAIDMAX RX-1200AE 1200W ATX12V v2.3 / EPS12V SLI Certified CrossFire Ready.
Ok so there are tjhe internals for my actual pc side of it i guess you could call it. Now to keep all this cool and achieve the clock speeds that i want i am going to need one h*** of a case and a very good liquid cooling system this is why i have been lurking for so long. If i forgot anything or you all know of something that might better suit my needs please feel free to reply and let me know, also please let me know what you think of my build.
Liquid cooling setup
I am going to have 3 seperate loops
1st loop
resevoir-pump-processor-chipset-radiator-radiator-flow meter-resevoir
2nd loop
resevoir-pump-GPU's-radiator-radiator-flow meter-resevoir
3rd loop
resevoir-pump-memory-hardrive-hardrive-radiator-radiator-flow meter-resvoir
Dedicated power supply-XFX P1-650X-CAH9 650W ATX12V v2.2 / ESP12V v2.(just for the liquid cooling and the fans and controllersw)
3x Lamptron FC-8 Fan Controller - Black
3x Bitspower Water Tank Z-Multi 250 Inline Reservoir
6x Black Ice GTX Xtreme 480 Radiator (yes you read correct 6 radiators, I KNOW I KNOW overkill much, but ive always been the type go big or dont go, and the h*** with starting simple and working to advanced)
Swiftech MCP655™ 12v Water Pump w/ Speed Control
Koolance CPU-370 Liquid Cooling Extreme CPU Block - Rev. 1.2
2x Danger Den Aqua Drive Hard Drive Water Cooler
3x Koolance VID-AR687 Radeon HD6870 VGA Liquid Cooling Block
4x Koolance RAM-33 Ram Liquid Block
3x Koolance INS-FM17N Coolant Flow Meter
3x Custom Thermal-Star / Bitspower Liquid Cooling Temp Probe Display
20 feet Tygon Silver Antimicrobial Tubing - 1/2" ID (3/4" OD) - Silver
PrimoChill Anti-Kink Coils - 3/4 OD" Tubing - UV Blue
and then i am going to have 8 fans on each radiator in push pull i am looking for fans around 64-70 cfm at 1500 rps or so i have found some but i cant get ahold of anyone that has 48 of them, this is ok though i may just order them as i can, it will take me a while to build this rig anyway i am going to estimate 2-3 weeks just sleeving all my cable alone.
The case i have found to sueeze all of this in is actually 2 cases
The case is going to be made to fit together so it appears as 1 Made by mountain mods
Bottom half(where both power supplys, radiators, 48 fans for the radiators, 12 case fans for exaust, my fan controllers, flow meter, and power buttons will be located)
Extended U2-UFO
left side and right side will have tripple quad pannels
the front will have the duality pannel with the bays on bottom, and 6 120mm fan cutouts on top.
the back will be a custom panel just like the front except 2 powersuplly cutouts instead of device bays.
The top will be solid with a smiley face cut into it, for tube routing and wire routing.
The top half
Extended U2-UFO
front opti 1203 panel with bays on bottom(extra large bays incase i decide to add something later or go with bay resevoirs instead)
left side big window panel
right side big window panel
back will be the tstand panel with horizontal motherboard brace.
I am undecided on what finsh to go with but i will figure that out in the next week or two while i am still fine tuning my design.
I know what fittings i am going to use for my connections, but i do not want to use hose between the 4 memory block, or the 3 GPU block, so what would be the best fittings to get where they will just connect directly from block to block, that way i only have one hose in, and one hose out. Also i am wondering where the best place is to by cable sleeves and cable extensions. And the lastly i am undecided on what kind of coolant to run, i read somehwere that if i use silver hose, and no alluminum on the internal of my loop, then all i have to do is run distilled water, is this true what do you all think? I have read probably 100 different arguments on what to use and what not to use.
Like i say it will be a little while before i get some pics up and actually get the build going becuase i want to have everything planned out and designed out D*** near 100% if i can that way i dont have to reorder and wait and and that c***. I am also going to be purchasing my products in 3 different stages so this will be a long term build i do hope that you all will bare with me as i know most builds do not take this long, but since this is my first build i am going to take it slow, and i also have to finance it with cash, lol so it will take a few paychecks to get it all.
Stage 1 order case(will happen within 3 weeks)
1a assemble case make sure everything fits together like its suppose to.
1b post pics of case
1c take case appart for easy access to bottom half
State 2 order radiators, fans, power supply, tubing, wire sleeves and extensions, and also fan controllers, temp guages.
2a leak test radiators.
2b install fans onto radiators.
2c power up make sure fans work.
2d install fans and radiators in bottom half of case.
2e Post pics.
Stage 3 order periphials and rest of liquid cooling.
put together install tear appart sleeve wires hid wires post as many pics as possible
Stage 4 benchmark post pics lots and lots of finished porduct.'
Thanks for all help and suggestions in advance
liquidnewb
EDIT EDIT EDIT
Ok so my first build proposal was retarded, in theory was bada** but quickly learne from the repies below that it was not, so with the help of m0r7if3r, Daemonkin, loopflow, conumdrum, ajex i have came up with a better solution for my needs, and been directed to some really steller threads that i have learned much more from(before hand thought i had it all figured out form just lurking around for a couple months, but still had much to learn)and still do have much to learn, but here is my new proposed build:
I am going to be doing a dual build my old computer updraded a little bit and then my new toy all in the same machine so here we go the new build we be labled side1 for now on, and the old updated will be labeled side 2
Case: Extended Ascension
Front panel: Trinity
Left/Top/Right panel: big window
Back panel: Duality
Finish: wrinkle powder coat black.
Side One:
PC Componets
CPU-AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz
Memory-G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
GPU-2x PowerColor AX6970 2GBD5-M2DH Radeon HD 6970
HardDrives-3xWestern Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb raid0
Optical drive-2x LG Black 10X Blu-ray Burner
power supplu-Antec TruePower Quattro Series TPQ-1200
motherboard-Asus Crosshair IV Extreme AM3/ AMD 890FX
os-debating 7pro or 7 ultimate onyl difference i found was language packs
2x Scythe S-FLEX SFF80C 80mm Case Fan
Liquid Cooling Componets:
2xBlack Ice GTX Xtreme 360 Radiator
2x Koolance VID-AR697 Radeon HD6970 VGA Liquid Cooling Block
1x Koolance MB-ASC4E (ASUS Crosshair IV Extreme) Liquid Cooling Motherboard Block
1xKoolance CPU-370 Liquid Cooling Extreme CPU Block
PrimoChill Anti-Kink Coils - 3/4" OD Tubing - Silver
PrimoChill PrimoFlex PRO LRT Tubing 1/2"ID 3/4"OD with 1/8" Wall - UV Red
12x 120mm fans undecided again push/pull
1x Koolance RP-402X2 Dual 5.25" Reservoir
2x Danger Den / Laing DDC-12V Center Inlet 18 Watt Version 3.2
loop 1 resevoir-pump-whatever looks best
loop 2 resevoir-pump-whatever looks best
Side Two
Parts from current build-
Processor: AMD Phenom x4 black edition
motherboard: Gigabyte MA785GMT-UD2H motherboard
Power Supply: 600 watt OCZ Stealth stream powersupply
wireless card: lynksys wireless-n pci adapter
memory: 8 gb corsair dominator ddr3(forgot the clock speed on it)
HardDrives: 2 seagate 500 gb 7200 rpm drives in raid 0
SSD: 1 120gb corsair ssd
BlueRay: 1 lg bluray r/w drive
GPU: 1 5870
Liquid Cooling Setup
CHC-122 nb chipset block
CHC-125 sb chipset block
VID-AR587T2 graphic card block
PrimoChill PrimoFlex PRO LRT Tubing 1/2"ID 3/4"OD with 1/8" Wall - UV Blue
12x 120mm fans undecided on which ons again push/pull
So this looks pretty good i think, not to much overkill and plenty of room for expansion i nice median in the middle i think, what do you all think. The only thing left is to figure out what the best compression fittings are to use with my compenets and blocks, what are ya'lls favorite fittings?
And also i am trying to figure out what are the differences between windows7 pro, and windows7 ultimate besides the language packs, is there anything that is really needed in windows7 as far as gaming advantages, and or benchmarking and overclocking?
1st loop
2nd loop
3rd loop
Extended U2-UFO
The top half
Extended U2-UFO
2e Post pics.
liquidnewb
EDIT EDIT EDIT
Back panel: Duality
Side One:
PC Componets
Side Two
GPU: 1 5870
