- Apr 18, 2017
Hi,
recently i bought Sabertooth 990FX, so my cheap air cooler is not enough now. I would like to start with water cooling, but because i'm stingy, i want to build it myself as cheap of possible.
First of all, my configuration is:
Phenom II x4 955 BE
MSI GTX 560 twin frozr 2
Sabertooth 990FX
Chieftec GPS-650AB A
HAF 922
I calculated total TDP of my CPU and GPU after max overclocking (+pump) at 376W. According to spreadshirt from this tutorial, with 2x 120mm radiators and 5,7 l/m i should get somewhere about 10-15 delta T. That's awesome, because i don't think i will run my CPU and GPU at full load at the same time Of course i will put 2-4 fans, depending on FPI.
http://www.tomshardware.co.uk/forum/277130-29-read-first-watercooling-sticky
After that, i want to use peltier unit, to give me a little more heatroom. I will simply make a sandwich of water block, peltier and my CPU cooler (SilentiumPC Fera 2 HE1224). I will turn on the peltier unit only when needed, mainly depending on radiators. For now i have 50W one, but if this will work, i will buy 100W unit. Of course it will be driven by external power source.
As a pump i want to use this aquarium pump:
http://www.sunsun-china.com/en/product/html/?222.html
It should give enough flow and pressure, and is made to work 24/7.
I will put it in some plastic box filled with water, and make holes to get the water in and out.
I want to have in my loop (in this order):
-CPU
-GPU
-GPU vrm
Pump will pump water to peltier, after that will be CPU, GPU, GPU vrm, to chiller and then reservoir with pump.
I'm wandering where to put it, i can place it inside the HAF 922:
-On top i will put my chiller with fans
-As a rear fan i will put my CPU cooler with paltier
-Water blocks of course on things
-Water pump with reservoir at bottom
I can also put it all on some board, at put it on top of my computer. I know that this is better option, but i don't know if this will make great difference, in this loop.
Placing it in the computer will be much cleaner. I have one 200 mm on front, and two 120 mm fans on side pushing the air inside.
So, it's my first water cooling system (and it have to be cheap, i can't spend 200$ on "easier and better" products), i don't have any experience and i made it after reading few articles.
I will be thankfull, if you could check if i'm correct everywhere, or if there are any mistakes.
Phenom II x4 955 BE
Sabertooth 990FX
HAF 922
-CPU
-GPU
-GPU vrm
