No.clocker2 said:SureFoot,
Using the setup that you propose ("fan-pulling-in-case") and granting that there will be a noticable drop in CPU temp...
Aren't the benefits gained offset by the effect of the now heated air on the rest of the system components.
After all, everything else in the case has now also been raised in temp, no?
Including the pump, the tubing, the waterblock, etc., not to mention the HDDs and optical drives.
Is this not a case of robbing Peter to pay Paul?
First you have to make sure that the air is going OUT of the case somehow, so it helps with air circulation. Next i said that air exiting the rad is quite cold, colder than regular inside case temps. If the air exiting the rad is TOO hot you can always duct it to a side panel or anywhere else. But experience tend to prove otherwise : i went that way too (my first setup was air pulled outside from inside). The air exiting the rad is NOT hitting at 100% every component you mentioned. It only helps creating a small 'draft' that will prevent 'hot air pockets'. In my setup (try to visualize a YY cube with a heater core above the PSU) the fan is blowing on the opticals / HDDs. HDD temps dropped by 10°C that way (they're in aluminium enclosures) and opticals are cooler (to the touch..). Note that i have a YY cube so my mobo is in a totally fanless zone, i use only convection.
