- Jan 15, 2009
My adventure with the board from hell continues:
I upgraded to Win 7 in October, and things were pretty sunny for a while. I had to dial back my overclock to stock on my Phenom II 920 because Vista just didn't seem to run right. XP ran fine at 3.5 GHz. Go figure.
Since I was running at 2.8 for a while, everything was working okay with Seven, but suddenly my temps froze up. Usually before, it was just the Tcase CPU temp, not the NB and system temps as well. And that only happened when I was OCing. If I reflashed the BIOS, the Tcase temp would come back as long as I ran at stock speed.
Last week, when the temps messed up, I reflashed and it did no good. Two days later I lost all of my HD temps in Speedfan, but I can still see them in HWMonitor. I still have a normal core temperature, so I thought "screw it" and jacked up the FSB.
I now have a stable OC of 3.3 GHz with a max core temp of about 52C. The system temps read at boot up and will show a static value. A reboot after a few hours will show a higher CPU temp when the system comes back, but it won't update. But I know the temp is being read because I used an IR thermometer to compare, and the case temp is pretty much what Speedfan tells me. It just won't update.
Anybody have any ideas?
EDIT: The current BIOS version is the latest from Foxconn: P09
