- Jan 6, 2005
My wooden case!
I have edited this main post now so I will just use it for my updates.
My case will be made out of Maple and Birch plywood. It will be stained mahogany, and will be 13 inches tall, 13 inches wide, 16.25 inches long. Able to hold 5x 3.25 drives, and later on I might add brackets for smaller 2.25" drives.
It will have 1x 200mm fan in the front, and 2x 140 mm fans in the rear. Holds two optical drives, and allows for nearly 14 inches of expansion for any graphics cards in the future.
