- Nov 30, 2008
My Seagate Barracuda 7200.11 died last night It had about 440gigs of data on it that wasn't backed up. Completely my fault too ... I had bought a 2tb drive last week when newegg had the $90 special and the new drive (which was supposed to back this and a 1.5tb one up) was just sitting on my table. I told myself I'd clean my pc's interior and stuff when I installed the drive so had been putting it off until the weekend. Everest showed all hard drives as perfectly healthy, so I wasn't that concerned ... well the drive died yesterday
The drive seemed to be working perfectly. Everest showed it as healthy with no issues, it never made any clicking noises, and it transferred data fine. I was using it as my dump drive so it was under a lot of use. I turned my pc off to go to bed and it was working fine. About 2 hours later of not being able to sleep, I decided to surf the net and turned my pc on. The drive did not show up under "my computer." I restarted a couple times and nothing. I then entered BIOS and checked to see if it was showing up there, it wasn't.
I stuck it in the freezer for about 10 hours and tried it again using my eSATA slot and it didn't work. I could definitely hear it spinning and powering up. It seemed to be spinning the whole time I had it connected but it just wouldn't show up on my computer or in BIOS. I stuck it back in the freezer and did a few google searches. This article seems to describe what happened to mine, except that I can't be sure this is the issue: http://www.theinquirer.net/inquirer/news/1050374/seagate-barracudas-7200-11-failing
I was using this drive as my dump drive which means the data I lost was all my newest stuff So I'd really like to try something out if anyone has any suggestions? The drive is sitting in the freezer right now wrapped up in an anti-static bag and a few zip-locks. That article mentioned the drives having the issue were from thailand, which mine was.
- edit - Just checked the drive and it was the "Drive origin and firmware seem to be Thailand and SD15" as the article mentions.
