I built the following system (not the one in my sig):
Abit IC7-G
Intel P3 3.0
2x512 GB ddr 550
2x 250 WD SATA in Raid 0
Geforce 6800 GT
Antec TrueBlue 480W power
DVD-RW burner
Koolance Exos with waterblocks on CPU and Northbridge
I installed Win XP plus service pack 2 plus all my software and games.
The system ran fine at 3.9 GHz, with no temperature issues.
In the middle of a game, the system shut down. Since then, I was able to boot back up, so I went into BIOS and reset CMOS.
When I hit F10, the system goes dark All the fans turn, the red and green led on the MoBo are lit and everything is powered up, but NO BEEP and NO signal to the monitor.
If I power down completely and wait 2 minutes, I can power back up.
Then the system gets to
'Verifying DMI Pool...Update success'
And just sits there.
A restart at that point will bring me a dark system again (powered everything but no video output).
A boot from cold and hitting CTRL-F or F4 to get into the raid config, gets ignored.
I swapped out the video card to eliminate that as a potential problem (no video signal), but the behavior is the same with an old Geforce 2 MX.
Is my MoBo FUBAR ? Any ideas / suggestions?
Abit IC7-G
Intel P3 3.0
2x512 GB ddr 550
Geforce 6800 GT
DVD-RW burner
