- Oct 13, 2002
- Carrboro, NC
Totaly on the cost part. I would have way way too much fun with the left overs from the paycheck
youthemandan said:Not really in 3 hours i didn't even use all 10 litres
I don't get it, what woud that do?JFettig said:you should freeze a can of shaving cream and peel off all the tin, and stick it in an evil teachers car
OC-Master said:
Blkout,
Your Sig is way oversized and you must reduce it before it comes into the hands of mod. Please make life easier for our forum moderators and do your part, reduce amounts of lines in your sig to 8 or use a smaller font.
To that other argument.
Clock for clock, the AthlonXP is much faster than the Pentium4. It also seems at the moment that the GeForceFX seems to be doing better on the Pentium4 over the AthlonXP because of the huge amounts of Bandwidth the P4 has. Both processors have there ups and downs but at the moment, the AthlonXP seems to have hit a ceiling at around 2.50GHz hence it cant seem to get to much more performance out of the CPU because of the limited bandwidth.
If AMD moves to a 400MHz FSB untill hammer arrives then it may have room to head a little further along and keep the compitition strong.
OC-Master
Banshee164 said:But if they increased the bus speeds you would increase the memory bandwith, resulting in an increase in performance overall. Look at the difference between nforce2 boards & 845PE boards running ram at 200mhz, mem transfer rates are alot higher on the Intel boards
