Ahhh yes, if only you could read. I never said a P4 clock for clock was faster than an AMD, I said a comparably overclocked CPU which means a maxed out AMD against a maxed out P4. Clock for clock goes out the window when your talking about which one gets from point A to point B the fastest.
I could care less if a 4 cylinder Honda Civic makes more HP per cubic inch than a Corvette, the bottom line is that the Corvette wins in the 1/4. Same situation here.
And Apple CPU is faster clock for clock than AMD or Intel, but you don't see them burning up the 3DMARK numbers do you? Why? Because all that matters is what you end up with, regardless of how efficient a CPU is. Intel's do some things better than AMD's and vice versa.
Why should I go to the Intel section? I post in all sections, I own both CPU's, AMD and Intel, but that's beside the point, even if I didn't own but one or the other, I still have the freedom to post anywhere I want.
You just seem to have your blinders on and won't admit one CPU's advantages over another. I don't have that problem. I've run both AMD and Intel for years. The bottom line is that you wanted to come here and brag and hopefully develop a little following like a cult. I even said nice OC, but then you had to light the fire between AMD and Intel. Don't forget, you started it, not me. Would you like me to quote your post?
