- Jun 10, 2003
- Eldersburg (Sykesville,) Maryland
This will be both the first computer I've built and the first one I've overclocked. I've done some video card OC'ing though, and with the experience I've gotten from my job (basically at-home desktop support, software/hardware install etc.) I'm pretty confident that I should be able to build something with a minimum of problems
I've been reading the forums here for about a month, and I feel like I've learned a lot! Between the stuff I've read here and the plethora of reviews I've read, I think I have finally more or less settled on buying the following:
Antec Plus1080AMG case with 430w True Power PSU
P4c- 2.6 ghz cpu
ABIT IC7 motherboard
2x512 Kingston HyperX PC3500
Zalman CNPS7000AL-CU Heatsink/Fan combo (and some AS3 of course)
Either 80 or 120GB 7200rpm 8mb cache HD (no SATA raid...yet)
I'm hoping for a minimum of 250fsb, with 275 really being the max I want to push my first OC- and on stock (or close to) core voltage. Money is an issue for me, so everything has been chosen for max performance vs. cost, as well as ease of attaining a higher OC (hence the 2.6c and its higher multiplier vs. the 2.4 c.)
The only thing I'm really not sure of is my choice of memory- I was initially going to go with some Corsair XMS 3200, but decided to go with 3500 after what I've read here. Corsair is too expensive at that speed, and the HyperX seems to be a good alternative. The other types of ram I was considering was Twinmos PC3700 and Buffalo PC3700...but I heard that the twinmos 3700 used chips that weren't so good for OC'ing, and I don't really like the latency on the Buffalo stuff.
What do you guys think of my choices- good stuff? I'm planning on getting it from newegg/googlegear- and I will actually be making the purchases in a few months as money is too tight now. By then everthing should be cheaper anyways- but its still fun to plan it out now
P4c- 2.6 ghz cpu
