- Jun 5, 2009
- Sydney, Australia
WoW is a CPU intensive game. Most MMOs are especially for heavy raid scenes.
What about D3? How does that run? Or anything newer.
Guild Wars 2... City of Heros, Rift, World of Warcraft...are CPU dependant titles.
A few other games that suffer greatly from older or weaker CPUS are Planetside 2... There are others, but these are fairly new titles.
Set FSB back to 200, even a couple MHz over isn't worth it -- you want to focus on the cpu-nb running at 2800 or 3000, and ram speed/timings for best case throughput on your system. In order for this config to run stable on my Biostar T series board I had the NB voltage bumped to 1.24 and the cpu-nb @ 1.34 to 1.400, temps good. Newer boards have much more headroom in terms of the durability of the circuits, allowing for higher voltages and temps and overclocks. Your gigabyte bios and settings will be different but the hardware is the same at the core. Detune your CPU multi a notch in order to test reliability of the NB. If you can get your CPU-NB stable, try to trim the timings down and use 90ns memory response times instead of stock 110 or 320. Attempt using the 1T command rate, see these screenshots (use aida64 to benchmark or torture test. - even though I have the X6 in these, I did it the same with a 965 x4):Ok, so after reading a few replies last night I did some rework to my OC. I was able to get my NB up to 2540 stable with a slight voltage increase ( NB & HT). Even through changing my cpu frequency to 211 no matter what I did I couldn't brake 2600. How safe of a voltage increase can you do to the NB before I fry it?
