- Apr 16, 2004
- new mexico
my win 7 install experience ...
current system:
opteron 165 (stk), wc'd w/ swiftec apogee v2, bix120.2, swiftec mcp655
dfi lanparty nf4 ultra-d
2gb (2x1gb) corsair platinum 2-3-3-3-8 1t
1x evga 7900 gs ko (stk)
1x wd160gb sata - os boot - win xp 32bit svcpk 3
2x wd36gb raptor - raid 0 - new - empty
1x lg dvd/r - pata
1x 250mb int zip - pata
1x 3-1/4 floppy
sunbeam fan controller
so the obvious approach ...install win7 to my empty raptor raid drives, sounds simple. right?
first run: custom install ... sees raptors as 2 separate dynamic 36gb drives, was able to okies well so
continue install, maybe it'll load appropriate drivers for the nf4 raid as it goes (supposed
to have all the drivers they say). 1st reboot, failed cant find ntloader (boots to xp np)
second run: custom install ... sees only 1 raptor, no drive options ... reboot nv raid shows raid failed
welp ... after multiple install starts, various combinations of 1, 2, can, cant, rebuilding in xp, d/ling vista
64 raid drivers, 3-1/2 hrs later ... i fianlly got it to install onto my 2x36gb raptors in raid 0
except for installing the nf4 vista 64 raid driverrs i havent needed to load any other drivers ... so far...
the only issue so far (got too late last night) is i cant see my 160gb wd drive with the xp 32bit os
so the final solution make sure you have the vista 32/64bit raid drivers (as req) and in xp (at least)
make sure you have your raid as undefined
current system:
1x lg dvd/r - pata
1x 3-1/4 floppy
