- Jun 11, 2004
The liquid in a heat pipe evaporates at the hot side and thus absorbs heat. The resulting gas travels to the cold side where it condenses and releases the heat. Then the condensed liquid is wicked back to the hot side where it evaporates again.OCnewbee said:I doubt there is any liquid in the heat pipes to begin with. Whats the point if you can't re-fill the pipe. Also if there was liquid in the pipe and the crimps were good liquid would evap anyways. Or the pipe would have to much pressure after time and pop. The heat pipes are hollow to begin with, unless the liquid can be circulated. through the heat pipes, then thats a totally different situation.
There has to be some liquid in a heatpipe for it to work, but flooding slows down heat transfer, hence you don't want very much of it.
