- Jan 12, 2012
Speether, at what MHZ have you had this processor stable for two hours of prime at? Unless you are benching your gains at 4.4 are going to be minimal compared to the amount of cpu v-core that is going to be required to take you there. We have also seen that at some point these FX chip are hard to overclock on the multiplier alone. Sometimes you need to start using the FSB but this also changes other things, such as you memory speed, ht link and nb frequency. So it shouldn't be done until you are comfortable with changing other parameters in the bios. Furthermore to the point of what Johan was saying, what case are you using? It really does make a difference and 2 120mm fans are probably not moving enough air inside that case, unless they are really high CFM fans.
