- Apr 5, 2011
Hi everyone! I just registered for the site but I have been coming here for awhile now for tech info. Here is my problem.
I just recently bought a Sapphire Radeon HD 6950 2gb. It is the one that looks like the reference card, not the one with the Sapphire cooler on it. The problem is the darn thing is HOT. I am running stock voltages and settings on my whole rig, nothing is overclocked and only the ram is tweaked. I have nothing but stock cooling on everything, which you would think would be sufficient. Well when it comes to this card it isn't cutting the mustard.
Just to give you an idea of the heat, I am sitting here typing this, and the card is sitting at 52C. My last card was a Sapphire Radeon HD 5750 1gb, it had the Vapor-X cooler on it, and it topped out under full load at less than this card runs at idle.Now the idle speeds I can handle. The problem is when you are gaming the card pushes 90C and higher. It has crashed twice so far in Champions Online due to heat issues. The sad thing is it used to be even hotter.
First thing I did was take the side off my case. This dropped it from 100C to around 95C under load. Next I went to Walmart and bought a laptop cooler with 2 fans on it and stuck it with it blowing inside. This had almost no noticable difference, so I bought a small Wind Tunnel fan and now I have that blowing into my case from the side. That brought it down to the temps I listed above. Thse temps just aren't going to cut it. What can I do here?
I have never dealt with heat issues before this so I have no idea. I know the card is going to eventually wreck if I don't cool it better somehow. I can't afford a really expensive cooling solution. Any thoughts? I had considered maybe using that Sapphire Trixx program and setting the fan speed control to manual and having it running at 100% all the while I am gaming, then I could turn it down on the desktop. The problem here is tha what happens if I forget to turn it up when I game.
I am like totally lost when it comes to this stuff. I thought about buying one of them aftermarket coolers but I have no idea how to install them or even what the prices are or what. I do have a decent amount of pc knowlege and this is my I think 3rd build I have done for myself plus at least 6 for other people so I know how to build them if it required taking the video card apart I could maybe do that, but honestly it is still under warranty and that just doesn't sit too comfortably with me. Just wanted to add that I have no and wouldn't even think of doing that 6970 thing to my card where you basically turn it into one. With how hot it is already I could only imagine a burning piece of plastic and metal. So can I get some people who know alot about cheap cooling methods to give me some insights? What are my options here?
