Hello everyone,
I'd like some advice on a new set of speakers to replace my antiquated Logitech Z-680 (no, I never thought they were really good but I couldn't find an excuse to replace them in the past 9 years). Any suggestions are welcome and appreciated.
By the way, I read the other threads regarding speakers advice but while some of them were close, they didn't have the same needs/requirements than I do.
I would use them mostly for gaming (a mix of almost everything : FPS, RTS, MMOs, etc.) but I also regularly watch movies (I mean blu-rays, not youtube crap) and listen to music (mostly FLAC, some mp3s but nothing under 320kbps, various styles).
I'm mostly interested in 5.1/7.1 setups. Keep in mind that this is my main entertainment source and I don't have nor do I want a home theater setup with an HDTV. (Read my system specs below and you'll understand why)
I tried playing with headphones and I think it's ok but I'd rather have a good set of speakers. FYI, I have a pair of Shure SE530 for my music and a pair of Razer Carcharias for my laptop (not the greatest but they're decent, comfortable and not too expensive to replace if I damage them).
No USB connections, period. I tried 'em and I always end up with the sound cutting out because I tend to overload my USB hosts.
My budget is flexible: my target is around $500 but if it's justified I could go up to 2k. Oh and I'm Canadian so not all the products are available up here (limited suppliers, etc.), to make matters worse, I'm in the far north of the country so I don't have access to any decent retailers to test speakers/headphones.
Finally, here are my system specs (it's just my regular list so you have lots of unnecessary stuff for this topic):
MOBO: ASRock Z68 gen3 extreme7
CPU : Intel Core i7 2600k (oc'ed to 4.4GHz)
CPU Cooler : Corsair H80 sealed loop water cooling kit
RAM : 4x4GB Corsair Vengeance 1600Mhz class 8
Vid card : 2x EVGA GTX 570 Superclocked
Sound card : HT OMEGA | Claro
PSU : Corsair HX1000
ODD : Blu-ray drive LITE-On iHOS104-08
HDD :
1x WD Velociraptor 10000RPM 600GB
2x WD Black 2TB WD2002FAEX
SSD :
1x OCZ Vertex 3 240GB MAX IOPS (boot drive)
1x Patriot Pyro 120GB (40gb used as cache (SRT) for Velociraptor)
1x OCZ Vertex 120GB
Monitor : 2x DELL U3011 30" 2560x1600 (only 1 used for gaming)
Case : Fractal Design Define XL with Noctua fans (3 120mm, 2 140mm)
(EDIT 1 : specified that I read the similar threads first)
HDD :
SSD :
1x OCZ Vertex 120GB
