Hey guys,
I am trying to create a replicatable build for a 24/7 4.5GHZ OC. The parts are pretty high (consumer) end - price is a factor but negotiable, because this build is purely for development purposes.
The reason why I'm opting for the hexa-core CPU is because the IDE's, database and web services are becoming more multi-threaded and thus benefit from parallelization. Typically, on the .NET ASP.NET MVC project you might build up to 60 times a minute - hence, 15 second build times aren't acceptable.
Which of the following motherboards are preferred? (I'm looking at the Formula but I have read some people suggest the extreme instead - are there any tangible benefits?)
Asus Rampage iV Formula Intel X79 Socket LGA2011 ATX Motherboard
Asus P9X79 Deluxe Intel X79 Socket LGA2011 ATX Motherboard (P9X79D)
Asus Intel X79 Express Rampage IV Extreme Extended ATX Motherboard
Asus SABERTOOTH X79 Intel X79 Socket LGA2011 ATX Motherboard (SX79)
Here are the other components:
4x Corsair Dominator Platinum 2 x 4GB 2133MHz DDR3 Memory Kit (CMD8GX3M2A2133C9)
Intel Boxed Core i7 3930K 3.20GHz Desktop Processor (BX80619I73930K)
Corsair H100 Hydro Series Processor Cooler
2x OCZ Vertex 4 256GB Solid State Drive
Will using a H100 be good enough to support a 24/7 OC? I'm also looking to use these 3 IPS monitors (central 24" is rotated 90 degrees for coding):
3x Dell U2412M 24" IPS LED LCD Monitor
Any other suggestions regarding the monitor? IPS is a requirement for wide angle view and rotation. It's quite common that the client may sit with a developer to make quick small adjustments or that the developer demo's the application. Crappy LCD's don't make for a nice viewing angle for 9 people.
Given that the requirement is 3 monitors, what graphics' card is suggested that can handle all 3? This is not a gaming rig, but some UI's (Like IDE's) are graphic card-accelerated - I was considering something like the Asus NVIDIA GeForce GTX560Ti DirectCU II Graphic Card (ENGTX560 Ti DC2/2DI/2GD5).
Given a graphics card in that range, what kind of PSU should I be looking at? Will a 850 90% efficient PSU be sufficient, if so - any suggestions?
Your advice is greatly appreciated.
(PS. Anyone know of companies/individuals who custom build and OC these kind of systems in South Africa?)
