- Jun 25, 2008
Greetings,
I am going to upgrade my system and I have decided on the kuma proc x2 7850 and a couple sticks of 2gig ram
I own a saphire x1650 and a connect 3d x700pro
I would like to setup the dual card thing, (never done that before)
currently running xp sp3 32 bit, but I have begged Bill for a fresh reg several times as this system is like George washingtons axe, so, this time they may say no whereupon i will have another go at unbuntu linux particularly since I have learned that xp32 will not use the 4 gig of ram
I do a little photo work, some online gaming, but mostly surf, email etc
1.) reccomendations for a mobo under 150 that will let me run the two cards equally, address the 1066 5-5-5-15 ram correctly, permit me to OC some without being a genius
2.) should I get another x1650 so the cards arre identical?
the new stuff will go in the old case which is WC on the cpu and gpu, I will need to run a loop to the new card, but plenty of capacity in the pump and radiator old bord is gig k8ganf with a 939 amd1.8 and 2 gig
usually use gigabyte, leaning toward asus this time, heard bad about MSI and DFI. what happened to tyan?
THANKS
THANKS
