thatbonokid
- Feb 26, 2004
- Michigan
I am being offered 125$ for an FX-6300, a Biostar 760g (that doesnt allow my processor to hit the 4.1 clock speed) 4gb generic ddr3 1333.
I want to upgrade to at least a true 4 core processor and motherboard for 150$
(the fx-6300 is actually 3 cores)
The plus side is, i have another 4gb stick and can wait to get 8gb again..but I also have a water cooler and have been successful getting an fx 8 series to 4.8.
I have a gtx 570, BenQ XL2420TE and the works for CounterStrike Global offe. (CS:GO).
Processor is an important part to this game, and i notice it dropping below 144fps once in a while.
Which processor and motherboard should I pick from this site with the buy a processor get a motherboard for free deal they have(40 dlollars off any motherboard)?
http://www.microcenter.com/site/products/amd_bundles.aspx
^link to the site, best store EVER.
the deal is, 40$ off of any motherboard. So i could find one in the open box section at the store, for a little cheaper.
Please any input would help, I know nothing about the new AMD's.. this 6300 may be enough if it wasnt on this horrible motherboard...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138360
^that is the motherboard I have.. How horrible is it?
I only am looking for performance in CS:GO.. and ANY input would be helpful.. I play the game on LOW(preferred) and am using window 8(should i update windows 8) i installed windows 8 ultimate(legit copy, and downloaded from microsoft, burned image, and installed fresh) curious about windows 8.1 or any updates at all.turned them off after installation. Thank you for your time.
