Hi, first of all I'll just say I'm pretty new to overclocking. I've messed with settings in the past but just never had the time to deal tweak with it. I've searched forums all day for answers to my questions but no luck.
My main problem is I cannot raise my FSB higher than 240 I believe. After I save/close it just goes to a black screen and I just have to shutdown the pc completely and turn it back on. It always results in "Overclocking Failed!" Now I'm using bios version 1018. I have tried pretty much every version after this including the new one. It always upgrades successfully but this is what happens with ANY version above 1018:
No matter what settings I use in bios (even the defaults) It will result in the problem I described above: going to a black screen/OC failed!
So that is 1 problem but I figured it would be fixable just by configuring my bios correctly. My first goal is to be able to use a newer bios version and at least be able to boot. I need to know what exactly to put in my chipset config along with my CPU settings. This would in including timings, fsb, etc.
Now my second problem, once I get that first one fixed, is I can hardly even overclock without getting the black screen/OC Failed!
The highest I can OC my CPU to is 3.37 or something but it's not stable. The most stable speed I've been able to use is 3.31 but I want to go much higher. Changing my FSB to anything higher than 240 causes the black screen/OC Failed problem once again.
I would just really appreciate some advice on which settings should be configured to what. FYI: I have messed with my fsb and timings alot but I don't really know what it does too well. I just also educated myself with some sticky's on OC'ing and memory OC'ing.
Any help would really be GREATLY appreciated.
Setup:
Motherboard: Asus P4C800-E Deluxe
CPU: Intel p4 3.2 prescott 800fsb 1mb cache Socket 478
Memory: 1GB (512mb x 2) PC3500 Performance Series Dual-channel OCZ Optimized Kit
Video card: Sapphire ATI Radeon 9800 Pro 256mb
Heatsink: Swiftech MCX478-V
Bios version: 1018
Temp: 46c Idle | 55c stressed
Thanks Again.
Setup:
Bios version: 1018
Thanks Again.
