dams.michal
- Apr 28, 2015
Hi,
As the title says this is going to be my very first Water Cooling Build. So I need some build advice. My goal for water cooling is to try to make this as silent as possible in everyday usage, but under heavy load (for example gaming) I want to have better performance.
Here is my PC hardware:
Case: Corsair Obsidian 900D
Motherboard: Asus Rampage IV Black Edition
CPU: Intel Core i7-4820K
GPU: 2 x Asus GTX 970 Strix
RAM: 4 x 4GB Kingston DDR3
PSU: Corsair AX1200i
After some reading I came up with a list of components that I think should fit my PC configuration:
CPU block: EK-Supremacy EVO - Acetal+Nickel (Original CSQ)
2 x GPU block: EK-FC970 GTX Strix - Acetal+Nickel and EK-FC970 GTX Strix Backplate - Black
Motherboard block: EK-FB KIT ASUS R4BE - Acetal+Nickel (Original CSQ)
I was thinking about building 2 loops (first loop for CPU,motherboard and second loop for graphics cards). In the initial planning of first loop I was thinking about 1 x EK-CoolStream RAD XTX (360) radiator, and for the second loop 1 x EK-CoolStream RAD XTX (480) radiator. All radiators will be mounted with fans in push/pull configuration. For the fans i was thinking about Corsair Air Series SP120 PWM High Performance Edition High Static Pressure Fan. All fans will be PWM controlled.
After reading information about dual loops and single loops I started thinking if single loop with dual pumps will do better in my PC configuration. So there is my question: should I do dual loops or single loops with radiators combined. And the second problem will be if 1x480 and 1x360 radiator will be enough to cool my PC.
Any advice would be awesome.
