Hey champs!
Just decided to clock my CPU and as I'm currently just running it on with my stock cooler i might need another one.
I have a budget on around +-100$ and need to decide what cooler I should buy
My specs are:
Corsair (2x3) DDR3 [PC3-10700H] CMX6GX3M3A1333C9
EvGa GTX 680 2GB
Intel i7 930 socket 1366 @ 2,8 ghz(stock) going for 3,8 - > 4,0
6GB Ram
Gigabyte x58a-ud3r motherboard
Cooler Master: CM 690 II Advanced Case
I am going to buy a Intel Core i7 4770K 3.5 GHz (Haswell) later on so it would be good if the cooler fitted on that one also
My friend recommended the Corsair Hydro Series H80i cooler but I've read alot of bad stuff about that one. Should I go with the H80i or do you guys have any other better option?
A water cooler would be prefered
Thank's
My specs are:
EvGa GTX 680 2GB
6GB Ram
Thank's
