- Nov 14, 2008
- Redmond, WA
Hey all, this is my first most here. Its been awhile since I've overclocked anything, last ones were a Duron and a T-bird, seemed a lot simpler back then. I'm getting back in the game and would like to OC my E5200 with this system I just pieced together:
Gigabyte GA-EP43-DS3L w/ Thermaltake CL-C0034 on NB and SB (on the way)
Intel E5200 w/ Arctic Cooling Freezer 7 Pro
Foxconn 8800GTS 640mb w/ Scythe Musashi
G.Skill 2x1GB DDR2 PC6400 w/ Corsair CMXAF1 Fans
WD Raptor 160mb w/ attached 80mm Fan
Lian-Li PC65B Case
Silverstone 1000w power supply
I tried at first bumping up the FSB to 233 without anything else and the computer would restart a few times, then boot up, post, but the BIOS was reset. I tried a few different configurations but keep coming to the same outcome. Is there a setting in the BIOS I could be forgetting about?
Also, this is kinda wierd to me, I was looking at CoreTemp with my E5200 and for the frequency field it switches back and forth from 2500.14MHz (200.01 x 12.5) to 1200.07MHz (200.01 x 6.0).
The Core temps read:
#0 37C
#1 16C (?)
Is that normal?
Any help would be much appreciated.
Thanks!
Lian-Li PC65B Case
#0 37C
#1 16C (?)
Is that normal?
Thanks!
