- Jun 7, 2006
- Idaho
So I'm looking to purchase new parts for both my systems. Most likely will only do 1 (My Rig) liquid cooled and the other just stay air cooled unless the cost isn't to bad. In anycase I'm wanting to have a closed system for the CPU & GPU. I'm going to be getting a Intel Devils Canyon 4GHz CPU (most likely or possibly the 3.3GHz 6 Core, still go back & forth) and then a eVGA GTX 980 Hydro.
I want something that has a good track record, has low maint. needs if any as well as ease of putting together, a kit would be great instead of having to pick & chose separately. Also I'm restricted to only using what available on Newegg.com as I will be using my newegg acct to get it all. I most likely won't be doing any major overclocking but will probably do some minor at some point. Also I have a large case now though will probably be upgrading to a new one but will be around same size. Current have an Thermaltake Armor+ Monster case its like 22x24x9 or some such.
Thanks
Thanks
