- Sep 27, 2003
Hello, fellow OCForums friends! I haven't been here in a long time and was seeking help, so figured what better place than OCF!
Flat-Screen:
65" Samsung KS8500 LED (love this thing)
AV Receiver:
Pioneer VSX-822
HTPC Hardware:
ECS KBN-I
A6-5200 APU
8GB RAM DDR3 1333
Radeon HD8400 / R3 (this should be the APU)
SSD for OS and apps
Software:
Windows 7 Pro x64
Kodi (for my entire library of shows/movies, mostly MKV)
PowerDVD 13
Windows Media Center with HD HR Prime Tuner
So I'm using Windows 7 for two reasons:
So... does anyone use an HTPC as both a TV Tuner and for 4K Video?
Is this a bad combo to use HD HR Prime and also desire 4K video from the same machine? I feel like one holds the other back.
I want to be able to play 4k MKV from my library, but not sure what's going to hold me back. If I need a better video card or APU, I'll upgrade, but I'm worried I'll have to run 4k as my resolution and then lose my TV tuner.
Help! Thanks.
Flat-Screen:
AV Receiver:
Pioneer VSX-822
HTPC Hardware:
ECS KBN-I
A6-5200 APU
8GB RAM DDR3 1333
SSD for OS and apps
Software:
Windows 7 Pro x64
PowerDVD 13
- TV Tuner -- if I recall correctly I couldn't get Windows Media Center (WMC) to work with HD HR Prime, and that's important to me b/c it's my main DVR/tuner.
- Scaling -- I have to run 1080p resolution because Windows Media Center wasn't working with 4k. Not sure if anyone has advice here, but I set up 1920x1080 and everything ran great this way.
Help! Thanks.
