I have been out of the loop for quite some time and need some advice on hardware I have been looking at for a low budget PC to use as an HTPC (gave away current systems mobo and CPU)
Currently it is a 2.0 ghz Celeron on a Soyo SY-P4I865PE Plus Dragon 2 with 2 x 512 mb PC 3200 DDR and gforce6800 XT (AGP)
Here is what I have been looking at for as a replacement
CPU:
Opteron 146 $86
http://www.newegg.com/Product/Product.asp?Item=N82E16819103598&ATT=19-103-598&CMP=OTC-pr1c3grabb3r
or
A64 3700+ $88
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80719-5&prodlist=pricegrabber
Mobo:
( would like to use micro ATX for a small cube case when I find a good one)
(also DDR and AGP would be nice but I can upgrade to PCIx if I need to)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=249005&prodlist=pricegrabber
Abit NF95
http://www.monkeycircuit.com/itemdesc.asp?ic=MBD-ABT-NF95&source=G2 - $62
Case:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140137&prodlist=pricegrabber
or
http://store.pagecomputers.com/cata...ESSID=ifpcgsauepcktprc8r4489civ1#tab_overview
For a sound card ( need optical ) I was thinking
http://www.tigerdirect.com/applicat...004&SRCCODE=PRICEGRABBER&CMP=OTC-PRICEGRABBER
Should I maybe spend a bit more in any area? What would you recommend.
I would like to keep the cost down as much as possible but if it will make a large difference I could spend a bit more
Thanks
CPU:
Opteron 146 $86
or
A64 3700+ $88
Mobo:
Abit NF95
Case:
or
Thanks
