- Aug 4, 2012
- Thread Starter
- #21
Well, I think I am about to pull the trigger, but I have a question about the waterblock. Anyone know if I can put compression fittings on this waterblock for 1/2 ID, 3/4 OD Tubing? Been waiting forever for the guy at extremerigs.com to do his review on this WB, but tired of waiting. Anything I am missing from below?
Going to get
Swiftech MCP655 G3/8" Threaded Edition 12 VDC Pump With Speed Controller
- Fittings 2 x Bitspower G3/8" Compression Fitting for ID 1/2" OD 3/4" (Chrome Look)
Bitspower D5 / MCP655 Mod Kit - Blue Finish
Bitspower CPU Block Summit EF (Intel) ICE Blue Acrylic Top Version
PrimoFlex Pro LRT UV Blue Tubing -1/2in. ID X 3/4in.
FrozenQ Liquid Fusion V Series 250 ml Reservoir - UV Blue (POM)
- Cathode Inverter Kit (No Bulbs)
- Reservoir Brackets Add UV Fluorescent Blue Mounting Clips
- Pair Bitspower Compression Fitting 1/2" ID 3/4" OD (Chrome look)
- (I was going to get the version with the side ports, because two outlets look cool, but not sure it is worth $50 extra so going with the normal version)
EK-CoolStream RAD XTX (240)
- Pair Bitspower Compression Fitting 1/2" ID 3/4" (Chrome Look)
AeroCool Shark 120mm Blue Edition 120mm Blue LED Case Fan x 2
White Sleeving kit
Going to get
White Sleeving kit
