- Feb 3, 2014
- sunny south florida boca raton
I have some what of an idea of how to do it from researching on my own. Any feed back and suggestions will be helpfull.
this is my plan...
i want to do a single loop. that will have two blocks and two radiators.
I will probably add a second gpu to it down the road.
parts list...
fan suggestions would help.
will the pump that i have chosen be ok for this loop. ( main concern )
I will put the smaller RAD after the CPU then to the GPU.
the pump's outlet is going to the larger RAD first.
my rigs specs are below and i have posted some pics of my current rig on my home page.
overall i would like it to be quiet and efficient
Any feed back or suggestions will be use full.
this is my plan...
parts list...
- Black Ice SR1 Low Air Flow Optimized - 360 Radiator - Black.
- Black Ice SR1 Low Air Flow Optimized - 140 Radiator - Black.
- Monsoon Series Two Premium D5/MCP655 Dual Bay Reservoir w/ Quick. Change LED Control - Matte Black w/ Blue Trim (M2-D5P-BL).
- PrimoChill PrimoFlex Advanced LRT Tubing 7/16"ID x 5/8" OD.
- Heatkiller Rev 3.0 1155/1156/1150 CPU Liquid Cooling Block - Nickel / Black
- Swiftech MCP655-PWM-DRIVE 12v Water Pump Module - PWM Enabled.
- hydro coper for my EVGA gtx 770 classified.
- coolant will be distill water clear.
