I have a some canned air that looks slightly wider then a can of soda. If I wrap this in insulation will it work? as for condesation, Im thinking about it. I might be able to set it in a metal dog food bowl and have the bowl on top of the peltier(yay, more ghettoness ftw).thideras said:That will transfer heat very poorly. You need something to help it transfer, maybe something in the shape of a can? Or use something bigger than a can and fill it with water?
No, I would not use coolant. You have to drink it sometime right? I wouldn't want coolant anywhere near something I'm drinking.freakdiablo said:Just a little update: instead of just water in the outer can, can I use some Thermaltake coolant for a liquid cooling system? Its just that when in the mini fridge, after about 24h, it would have sucked all the moisture from the inside and formed a block of ice at the top of the fridge, and the coolant says its anti freeze and anti rusting.
*sigh* no, that doesnt work. Let me fire up ps and show you.XeonStrikeForce said:small 1/8" sheet of aluminium or copper aut to do it.
thideras said:*sigh* no, that doesnt work. Let me fire up ps and show you.
EDIT: one sec, we had a few calls...
EDIT: I did not take the pic of the can, just edited:
See the ring, it will only transfer heat through that part on the bottom...the whole center of the pelt will not have contact...therefore, it will transfer heat very slowly.
It looks ghetto? good. my work here is done. The only reason Im using the 50w peltier is because it came out of a broken mini fridge, and I just felt like messing around with it. And the hsf came off my x2 4400+ (the 110w one).apt403 said:That has got to be the most ghetto lookin' drink coolers I've ever seen. But still, it looks awesome. I would take the 50w tec off and replace it with a 120w one. It would get your drinks a hell of a lot cooler, the psu can handle it, they're cheap as dirt, and any hsf that can cool a P4 or something of the like should be able to handle the heat.
Good idea, but sadly the rest of the fridge is at a dump somewhere.apt403 said:'K, so the peltier is being put to good use, what about the rest of the fridge? You could take a crappy PIII or something, or even a cheapo mini/nano-itx mobo, wrap it up in saran (sp?) wrap, chuck it in there, with HDD, optical drive, and psu sticking out, then fill the fridge up with dice. Or, if the fridge has been fixed, break it, then fill it up with dice and pc.
