- Sep 14, 2007
- Florida, US
Can you guys recommend one? I want to use an i5 CPU on it (1155)
I want to use it to install ROS on it (Robot Operating System) and i want to use 16GB of RAM on it... and want it to be less than $100
So it looks like newegg has about 4 different boards that will fit what i want.. Main difference is the North Bridge
So the options i got are:
B75, H67, and H77
This are the boards im looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186211
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157310
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157311
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131841
I dont think ill be doing any overclocking... Always been an Asus fan, but not sure if its worth it to pay $30 for it compared with the Foxconn which is $64 and has nice reviews
What you guys think?
B75, H67, and H77
