I'm going to water cool my computer and this is the first time i'm doing it so i need some advice.
The things i'm going to water cool is my i7, my two 660ti and maybe my motherboard (asus maximus v formula).
The parts i have chosed are:
gpu block: EK-FC670 GTX DCII - Acetal+Nickel
cpu block: EK-Supreme HF - Acetal+Nickel
pump: Swiftech MCP655
radiator 1: EK MCRx20-XP 360
radiator 2: EK MCRx20-XP 240
reservoir: EK MCRES Micro Rev2
fittings: Compression Fitting from EK
I have not chosen the tubing and fluid yet. I want it to be red but i dont know if i should chose red tubing or fluid, I have heard that you should avoid colored liquid becouse it can clog the loop. So should i pick a red tube and clear liquid?
Another question i have is does the thickness of the tubing any effect the performance?
The last question I have is will the two radiators be enough for everything im going to cool with the water loop?
