Hello guys, new to the site and watercooling for that mater.
I've been using AIO's for my cpu for a while, from corsair's to fractals, they give good temps but I've been trying to get the courage to go custom watercooling for a few years now and and I finally bought my parts, I put it all together including GPU block, my Asus Strix 1080ti preduces a lot of heat into my case, that was one of the main reasons I wanted to go full custom loop.
Here are my parts and system:
System:
Case: Lian Li PC-011 Dynamic
Asus Maximus XI Extreme
i7 9900k (stock speeds, no OC)
Asus GTX 1080ti Strix OC
Watercooling parts:
CPU Block: EK Velocity (full nickel)
GPU: EK GTX 1080ti STRIX
Radiator: XSPC EX360V2 Crossflow
Pump: EK XTOP DDC 3.2
Reservoir: Phanteks Glacier R220
Radiator fans: 3x Corsair ML120 Pro
The problem:
After putting everything together in my system (without leaks for a first timer ) I was getting great temps on my GPU, around 50c on 99% load but the cpu was getting very, very hot.. on a cinebench run was hitting 95c/100c..
Some thoughts:
I know 9900k is a heat hunger beast, on my AIO Fractals I get 75c on a couple of Cinebench runs, fine in my opinion.
Is it possible that my radiator can't deal with both parts? I did some research before buying, and a 360 should handle both my CPU and GPU..
Can someone please give me some advise of something that I might be doing wrong? Did I made a mistake in the parts I bought? Hope someone out there can help this watercooling noob..
System:
Watercooling parts:
The problem:
Some thoughts:
