- Oct 18, 2002
- Los Angeles
I bought this cheap-o piece of crap for $7 shipped off amazon http://www.amazon.com/gp/product/B00JGN4PBW/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
I knew it was going to have crap LEDs, so i ordered some of these guys: http://www.amazon.com/gp/product/B004UZCMRK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I took apart the control module and disconnected the annoying speaker, I soldered out the old LEDs and put the new ones in, and they didn't work so I noticed some resistors on the board connected to the LED wiring so I soldered those and bypassed them completely, now the new LEDs are working. Also, Instead of using 2 AA batteries, I will be using 3 AA batteries so upping the voltage from 3V to 4.5V, the LEDs are much brighter with the extra battery, the old LED lights worked on 3 just fine and so I figure the new ones (which are rated up till i think 12v? should work great with 3 batteries too)
The problem is with the actual "Blinker" LEDs, they don't seem to be attached to any resistors and I'm guessing the same parts that make them blink are the ones that are limiting their voltage... this is where I need help. I have almost no electrical engineering knowledge.
I found two parts on the motherboard that are round orange things labeled C1=104 and C2=103 I believe these are the capacitors.
The resistors i bypassed are R1=51 and R5=51
The other components are:
R2=390k (the R's look like resistors)
R3=560
R4=18
Q1=9013
Q2=9012
Q3=9012
S1,S2,S3 (irrelevant switches).
The Q things each have 3 legs, i think these cause the lights to blink?
My question is, which parts do i swap out to make the LEDs for the turn signal work and still blink like the old LEDs? And which parts do i need? (I don't know how to ramp those parts up)
My guess (just for fun) is that i need to change the orange capacitor things and possibly one or two of the 3 legged switch things.
R3=560
R4=18
Q1=9013
Q2=9012
Q3=9012
