I tried to start folding on my old Gigabyte HD 7750 about a week ago and can't get it to download a wu. The cpu can get work no problem. I've tried deleting the directory with the config files; and reinstalling FAH in a different directory and neither have worked. Any other ideas?
Code:
*********************** Log Started 2016-11-13T21:12:49Z ***********************
21:12:49:************************* Folding@home Client *************************
21:12:49: Website: http://folding.stanford.edu/
21:12:49: Copyright: (c) 2009-2014 Stanford University
21:12:49: Author: Joseph Coffland <[email protected]>
21:12:49: Args: --open-web-control
21:12:49: Config: <none>
21:12:49:******************************** Build ********************************
21:12:49: Version: 7.4.4
21:12:49: Date: Mar 4 2014
21:12:49: Time: 20:26:54
21:12:49: SVN Rev: 4130
21:12:49: Branch: fah/trunk/client
21:12:49: Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:12:49: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:12:49: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
21:12:49: Platform: win32 XP
21:12:49: Bits: 32
21:12:49: Mode: Release
21:12:49:******************************* System ********************************
21:12:49: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
21:12:49: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
21:12:49: CPUs: 4
21:12:49: Memory: 3.00GiB
21:12:49: Free Memory: 2.16GiB
21:12:49: Threads: WINDOWS_THREADS
21:12:49: OS Version: 5.1
21:12:49: Has Battery: false
21:12:49: On Battery: false
21:12:49: UTC Offset: -5
21:12:49: PID: 5684
21:12:49: CWD: C:/Documents and Settings/xxx/Application Data/2FAHClient
21:12:49: OS: Microsoft Windows XP Service Pack 3
21:12:49: OS Arch: X86
21:12:49: GPUs: 1
21:12:49: GPU 0: ATI:5 R575A [Radeon HD7700 Series]
21:12:49: CUDA: Not detected
21:12:49:Win32 Service: false
21:12:49:***********************************************************************
21:12:49:<config>
21:12:49: <!-- Folding Slots -->
21:12:49:</config>
21:12:49:Connecting to assign-GPU.stanford.edu:80
21:12:50:Updated GPUs.txt
21:12:50:Read GPUs.txt
21:12:50:Trying to access database...
21:12:51:Successfully acquired database lock
21:12:51:Enabled folding slot 00: PAUSED cpu:2 (not configured)
21:12:51:Enabled folding slot 01: PAUSED gpu:0:R575A [Radeon R7 250/HD 7700] (not configured)
21:13:03:13:127.0.0.1:New Web connection
21:13:52:Saving configuration to config.xml
21:13:52:<config>
21:13:52: <!-- Folding Slots -->
21:13:52: <slot id='0' type='CPU'/>
21:13:52: <slot id='1' type='GPU'/>
21:13:52:</config>
21:13:52:Set client configured
21:13:52:WU00:FS00:Connecting to 171.67.108.45:8080
21:13:52:WU01:FS01:Connecting to 171.67.108.45:8080
21:13:53:WU00:FS00:Connecting to 171.67.108.45:8080
21:13:53:WU01:FS01:Connecting to 171.67.108.45:80
21:13:53:WU00:FS00:Assigned to work server 171.67.108.158
21:13:53:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.67.108.158
21:13:53:WU00:FS00:Connecting to 171.67.108.158:8080
21:13:53:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
21:13:53:WU01:FS01:Connecting to 171.64.65.35:80
21:13:54:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:13:54:ERROR:WU01:FS01:Exception: Could not get an assignment
21:13:54:WU00:FS00:Downloading 806.61KiB
21:13:54:WU01:FS01:Connecting to 171.67.108.45:80
21:13:55:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
21:13:55:WU01:FS01:Connecting to 171.64.65.35:80
21:13:55:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:13:55:ERROR:WU01:FS01:Exception: Could not get an assignment
21:13:55:WU00:FS00:Download complete
21:13:56:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9031 run:183 clone:1 gen:222 core:0xa4 unit:0x0000010dab436c9e569834ed54f5c415
21:13:56:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/x86/Core_a4.fah
21:13:56:WU00:FS00:Connecting to web.stanford.edu:80
21:13:56:WU00:FS00:FahCore a4: Downloading 2.89MiB
21:14:01:WU00:FS00:FahCore a4: Download complete
21:14:01:WU00:FS00:Valid core signature
21:14:01:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe
21:14:02:WU00:FS00:Starting
21:14:02:WU00:FS00:Running FahCore: "C:\Program Files\2FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/xxx/Application Data/2FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 704 -lifeline 5684 -checkpoint 15 -np 2
21:14:02:WU00:FS00:Started FahCore on PID 5004
21:14:03:WU00:FS00:Core PID:4320
21:14:03:WU00:FS00:FahCore 0xa4 started
21:14:04:WU00:FS00:0xa4:
21:14:04:WU00:FS00:0xa4:*------------------------------*
21:14:04:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
21:14:04:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
21:14:04:WU00:FS00:0xa4:Preparing to commence simulation
21:14:04:WU00:FS00:0xa4:- Looking at optimizations...
21:14:04:WU00:FS00:0xa4:- Created dyn
21:14:04:WU00:FS00:0xa4:- Files status OK
21:14:04:WU00:FS00:0xa4:- Expanded 825458 -> 1397768 (decompressed 169.3 percent)
21:14:04:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825458 data_size=1397768, decompressed_data_size=1397768 diff=0
21:14:04:WU00:FS00:0xa4:- Digital signature verified
21:14:04:WU00:FS00:0xa4:Project: 9031 (Run 183, Clone 1, Gen 222)
21:14:04:WU00:FS00:0xa4:Assembly optimizations on if available.
21:14:04:WU00:FS00:0xa4:Entering M.D.
21:14:10:WU00:FS00:0xa4:Mapping NT from 2 to 2
21:14:12:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
21:14:27:FS00:Shutting core down
21:14:34:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:14:35:WU00:FS00:Starting
21:14:35:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
21:14:35:WU00:FS00:Running FahCore: "C:\Program Files\2FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/xxxx/Application Data/2FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 704 -lifeline 5684 -checkpoint 15 -np 3
21:14:35:WU00:FS00:Started FahCore on PID 3908
21:14:35:WU00:FS00:Core PID:312
21:14:35:WU00:FS00:FahCore 0xa4 started
21:14:35:WU00:FS00:0xa4:
21:14:35:WU00:FS00:0xa4:*------------------------------*
21:14:35:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
21:14:35:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
21:14:35:WU00:FS00:0xa4:Preparing to commence simulation
21:14:35:WU00:FS00:0xa4:- Looking at optimizations...
21:14:35:WU00:FS00:0xa4:- Files status OK
21:14:35:WU00:FS00:0xa4:- Expanded 825458 -> 1397768 (decompressed 169.3 percent)
21:14:35:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825458 data_size=1397768, decompressed_data_size=1397768 diff=0
21:14:35:WU00:FS00:0xa4:- Digital signature verified
21:14:35:WU00:FS00:0xa4:Project: 9031 (Run 183, Clone 1, Gen 222)
21:14:35:WU00:FS00:0xa4:Assembly optimizations on if available.
21:14:35:WU00:FS00:0xa4:Entering M.D.
21:14:41:WU00:FS00:0xa4:Mapping NT from 3 to 3
21:14:42:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
21:14:53:Saving configuration to config.xml
21:14:53:<config>
21:14:53: <!-- Slot Control -->
21:14:53: <power v='FULL'/>
21:14:53:
21:14:53: <!-- User Information -->
21:14:53: <passkey v='********************************'/>
21:14:53: <team v='32'/>
21:14:53: <user v='belorsch'/>
21:14:53:
21:14:53: <!-- Folding Slots -->
21:14:53: <slot id='0' type='CPU'/>
21:14:53: <slot id='1' type='GPU'/>
21:14:53:</config>
21:14:54:WU01:FS01:Connecting to 171.67.108.45:80
21:14:55:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
21:14:55:WU01:FS01:Connecting to 171.64.65.35:80
21:14:55:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:14:55:ERROR:WU01:FS01:Exception: Could not get an assignment
21:16:31:WU01:FS01:Connecting to 171.67.108.45:80
21:16:32:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
21:16:32:WU01:FS01:Connecting to 171.64.65.35:80
21:16:32:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:16:32:ERROR:WU01:FS01:Exception: Could not get an assignment
21:18:52:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
21:19:09:WU01:FS01:Connecting to 171.67.108.45:80
21:19:09:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
21:19:09:WU01:FS01:Connecting to 171.64.65.35:80
21:19:10:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:19:10:ERROR:WU01:FS01:Exception: Could not get an assignment
21:23:03:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
21:23:23:WU01:FS01:Connecting to 171.67.108.45:80
