- Sep 26, 2001
- Raleigh, NC
To make a long story short, a friend of mine bought an Emachines ER1401-57 to give to his uncle. It seemed like the perfect fit for him since all he does is surf the web, play cards online, and email a bit.
When he first got the system, the 2 GB of RAM it came with seemed like plenty since he wasn't doing anything demanding at all. But now, after months and months of updates to Windows, Windows 7 is now eating up all but about 250 MB of the installed 2 GB of ram. I'm aware Windows 7 will often use excess RAM for disk caching, but this isn't the culprit in this case as there doesn't seem to be enough free RAM for windows to even cache the drive, and it would be expected to release said RAM once another program needed it. He finally asked for help when Windows started giving him "out of RAM" errors.
So the gentleman is in need of a RAM upgrade for this machine, and I need to get some info before proceeding on it. It uses DDR3 so-dimms for RAM and has two ram slots. It uses an AMD Athlon II Neo Processor K325 as well. The processor is what has me asking questions, as I keep finding conflicting specs for it. Does this CPU make use of dual channel memory or single channel? I've seen conflicting specs concerning this. It really only matters because I have 1 spare so-dimm already that would get him up to 4 GB, but I need to know if his setup supports dual channel so I know if I should just get him a 2x2GB or possibly 2x4GB set. He's a fellow veteran on a fixed income so I'm trying to keep costs to a minimum while donating what I can to him for free.
