- Feb 17, 2011
Hello forum.
A week or 2 ago i made a topic here asking for some advice on a new UV reactive coolant. However the more experienced people here advised me to stay away from Colored coolants and use Distilled water/Colored tubing.
So after they convinced me to use distilled water i tried to ask as many questions regarding my setup. However i thought it would be odd to dig the topic up now with more totally off-topic questions.
Anyways, October/November last year i build my first water-cooling system. I have been building my own pc's since i was 13~ years old (now almost 20). However water cooling was a whole new step for me and i did as much research on parts as i could and ended up with a decent setup(i hope lol).
Sorry for the long-ish introduction! lets get to the actual questions.
This weekend i'd like to do some maintenance on my system and would like to change my coolant to distilled water and probably add some better fans for better cooling.
My setup currently consists of
-Corsair Obsidian 800D
-Corsair HX850 PSU
-Maximus IV Extreme-z
-intel core i7-2600k @4.5Ghz 1.376v
-G.Skill 16GB PC3-12800 (1600MHz) Ram
-N680GTX Twin Frozr 2GD5/OC (+150 core, +515 mem)
-Asus Xonar phoebus soundcard
-120GB OCZ Agility 3 SSD(OS) ||60GB OCZ Agility 3 SSD || WD Caviar black 1TB
Wit the following water cooling parts
- RayStorm Intel CPU Waterblock
- D5 Dual Bay Reservoir
- D5 Vario Pump
- RX360 Dual Radiator
- G1/4″ to 7/16″ Compression Fittings (Black Chrome) & 11MM (7/16 ID - 5/8 OD) EK-PSC Fitting 12mm - G1/4 Black
- XSPC 1650rpm 120mm Fan x3
-EK-FC680 GTX - Acetal CSQ + EK-FC680 GTX Backplate - Black CSQ
-Tygon R3603 - HighFlow - 7/16 ID - 5/8 OD - Clear
-Bitspower G1/4 Temperature Sensor Stop Fitting Matt Black BP-MBWP-CT
-Koolance 5-way Fitting Body (zilver) SPL-XUFY5B
-NZXT Sentry 2
As you might noticed i do have a draining system. Draining the system is not such a big deal. The actual water-block/Radiator maintenance is my problem.
All the water cooling parts where bought brand new and still have warranty on them. which brings me to the following dilemma! Do i take them apart to clean or not? it's only been 7 months~ how clogged up can it be?
And what advice do you guys have on flushing the blocks/Radiator?
is it allowed to clean it with normal tap water and then flush it with distilled water? Also when using distilled water what chemicals do i need to add to the loop?
And last but not least: i have been looking at the Corsair SP120 High performance edition fans for the Radiator. i currently have the standard fans that came with my case/Radiator. And i think these Corsair fans will be better performance/noise wise but i haven't looked so much at other options.
Also been thinking to get Either the Tygon R3400 - HighFlow - 3/8 ID - 5/8 OD - Black tubing or go with the DangerDen DD-TFC Tubing 3/8 ID - 5/8 OD - UV White but the DangerDen seems like cheap tubing that will plasterize in a matter of weeks(could be totally wrong though).
Thank you for your time and i apologize for my bad English spelling. i did my best to make it as readable as i could.
Please post your advice/suggestions
EDIT: I will be adding some pictures later this week showing the tubing and maybe the blocks after 7 months with the Feser One Cooling Fluid - UV ACID GREEN
-Corsair HX850 PSU
- D5 Vario Pump
-NZXT Sentry 2
