Need your advice - Which pairing phone with device offer better productivity Microsoft Apple Google for this tasks
Need advice from people that have first hand experience to answer this question
For the following tasks, by order of frequency:
Web browsing (for work). Website admin managing. Autofill for forms and user passwords. Also with lot of favorite making, ordering, and managing, web desktop shortcuts creation and filing, web saving as .mht or similiar, and also as print file, and as an image or picture snapshot. Preferably with mouse por fingers gestures or equivalent and super drag and drop link like feature ( drag and drop a link to anywhere you like and it will open in a new tab, preferably without taking you to the new tab). Managing different search engines from one place.
Dictation and Voice Recognition. Dictating long documents in any and all applications, and easy and straight forward use of voice commands to make the work faster when they help.
Managing lot of opened windows.
Managing ordering, lot of tiny files, mostly txt, pictures, spreadsheets.
Writing many text files, editing some source code from time to time, searching through long txt, make text replacements, search IN TEXT or IN FILE for a string of text in folders.
Spreadsheet creation and editing, like excel, or similar.
Image easy editing. Vectorial image easy editing.
I would appreciate some easy to use automation feature.
No gaming at all, No Movies, no entertainment in this pairing.
That should cover 99%.
Which pairing gives much more productivity, so as to get far more work done the fastest, anywhere, the easiest possible (intuitive, easy to use, and friendly software) with the least need to install or configure, and update, many different softwares:
Windows 10 Phone + Windows 10 2 in 1 (like lumia 650 + a surface pro or maybe a similar one from Asus, Acer, Lenovo, Hp, Dell)( I alswo want to know if you miss any feature in terms of compatibility between a windows phone and a 2 in 1 if the latter is not an original surface and instead is a surface wanabee from those other manufactures, in other words, if there is any propietary feature exclusive to microsoft surface, specially in terms of productivity, or easyness.
Google Nexus + Google Chromebook (like a Google Nexus x5 + Google Pixel C)
Apple Iphone + Apple Ipad Pro or Mac book ( im not familiar with apple)
Would you consider a better pairing of devices to get the aforementioned productivity higher make your suggestion, as mines are only rough ideas, as i try to grasp how the workflow on all this devices go.
Im lost in the voice side also after reading about cortana/Dragon Naturally, siri/Dragon Naturally and Google Voice Dictation (which apparently is still not avalable in cromebooks only in desktop version of chromeos or thats what ive read).
My impression is that chromeos is still far from this flexibility, as even managing multiple windows is not possible. I read about remix os but thats sounds like a poor reason to jump on it. On the other hand people talk about google voice dictation as the best one, and you have most needed apps on cloud and for free (although i dont like the cloud idea at all, but it looks that no matter which route u go you eat a cloud one way or another). Regarding apple it looks like the best one making all devices work toghether and including at no additional charge most of the software you will need to make all this work. I also heard lot of nices about Pages and Numbers, and lot of easyness in this side. Finally Windows is the most compatible, as far as you dont mind going after each one software, chosing them, buying them, then managing and trying to make it all work toghether in a single workflow. Also i have no idea if you get any advantage using a windows 10 phone along with a windows 10 2 in 1 next to using an android or apple phone with it.
Whats your expirience. Ive always being clustered inside Windows since the 3.1 + Dos.
