- Dec 23, 2002
- Doylestown, PA
I have been running a 1700 DLT3C JIUHB0307VPMW for a while now. For some reason I couldn't get my FSB stable over 203Mhz for a long time, so I left the overclock at 200x12.5 (2505Mhz). Well today I had nothing to do so I decided to tamper with it once again to see if anything beneficial would come out of it. I set the timings to 8-2-2-2, and the vdimm to 2.9v and the chipset voltage to 1.7v. I put the vcore at 1.875v (1.82v actual voltage), and lowere the multiplier to 5. I then tried to get the computer to boot with a 217Mhz FSB which is what my PC3500 is rated to run at. It booted up fine, so I ran memtest86 to see if it was stable or not. Memtest ran for about 3hrs and had no problems, so I decided to play with the multiplier to see how far the CPU could go with the FSB so high. I got it to run at 217x11.5 a total of 2496Mhz for 5hrs in Prime totally stable. So I sacrificed some overall Mhz for the extra FSB, but this is the highest I have ever gotten the memory to run on my system. Hopefully in the next couple days I will get it a little higher...I'll keep you all posted.
